Your Portal Version: 1.0.6
Boardlink: http://www.laryngo.com/forum/portal.php
looking in differents forums
creating new html files, looking explications in others forums
Hi everybody,
i'm the webmaster of laryngo.com, a small website dedicated in communication between french specialized nurses in anesthesia.
I'm tying to install board3 portal instead of my old HTML page.
All the installation went good, but i need to add 2 or 3 blocks customisables ton complete my portal. I've tried to read in différents forums the way to do this, but i didn't success.
At best, i'd just add the possibility, in the ACP, to add 2 center blocs and a right bloc in the "ACP / .mods / customisable bloc" menu. Now, i just can add 2 blocs (center and small left). I need 2 center blocs and 1 right bloc more.
Is there a way to modify custom.php to add this news customisables blocs ?
Thanks by advance for any help, and excuse me for my english.. I'm frenchs,
Regards,
Maxime
adding customisable blocks
maxmar
nlfighter
Re: adding customisable blocks
Hello Maxime,
I have browsed the forum and came accross your post. This problem is solved in the latest version Board3_portal_2_0_0b1. You can add as many custom blocks as you need and what is even more important for me change the place of the blocks right from ACP. I installed it yesterday and it works just perfect.
Regards,
Regards,
maxmar
THanks... I went to the knowledge base and i've managed to to this
knowledge/kb_show.php?id=51
Thanks a lot
Thanks a lot
