Your Portal Version: 1.0.6
Boardlink: http://www.hollandsbierteam.nl/
Upgraded phpBB from 3.0.7-PL1 to 3.0.8
What have you already tried to solve the problem?
A complete clean reinstall, checking the source code of the user menu module.
After the clean install, me and my users can no longer see the new posts or our own posts links from the User Menu module on the Portal.
New posts
Re: New posts
Maybe you should upgrade to phpBB 3.0.8.
Anyhow, could you provide a test account? You can send the details to me via PM.
Tag of Fire
- phpBB.com User: Tag of Fire
Re: New posts
I am not yet permitted to use the PM system, but I don't mind providing the test account details publicly.
Username: Test
Password: test123
Username: Test
Password: test123
Re: New posts
This is because of this:
This is not a portal issue.Je beschikt niet over de juiste permissies om gebruik te mogen maken van de zoekfunctie.
Tag of Fire
Re: New posts
I never knew the search function was a pre-requirement for showing those links.
Thanks for the info, I managed to fix it by re-enabling the search function.
Cheers.
Cheers.
