Where is it possible to change color of block ?
brandon
Post by brandon »
Where is it possible to change color of block ? i have update from 1.6 to 2.0.0 and the colors of the backgroung of block (left and rigt) have changed.
Thank for your help
Re: Where is it possible to change color of block ?
brandon wrote:Where is it possible to change color of block ? i have update from 1.6 to 2.0.0 and the colors of the backgroung of block (left and rigt) have changed.
Thank for your help
That you can in the root / styles / your style / template / portal / _block_config.html change.
Return to “Styles Support”
