Separate User and Bots on Index
RocknRoll
phpBB.com User: _RocknRoll
Post by RocknRoll »
I would like to get 'Separate User and Bots on Index' Mod to work in the "Who is online" block for Portal version 1.0.6
Forum index "Who is online"
Portal "Who is online"
As you can see installing the MOD half worked because it separated 'Registered users' and 'Bots' in the "{TOTAL_USERS_ONLINE}"
In total there are 5 users online :: 2 registered, 0 hidden, 0 bots and 3 guests
But doing the matching template edit did not work
OPEN: ./template/index_body.html
FIND:
<td class="row1" width="100%"><span class="genmed">{TOTAL_USERS_ONLINE} ({L_ONLINE_EXPLAIN})<br />{RECORD_USERS}<br /><br />{LOGGED_IN_USER_LIST}</span></td>
REPLACE WITH:
<td class="row1" width="100%"><span class="genmed">{TOTAL_USERS_ONLINE} ({L_ONLINE_EXPLAIN})<br />{RECORD_USERS}<br /><br />{LOGGED_IN_USER_LIST}<br />{ONLINE_BOTLIST}</span></td>
OPEN: ./template/portal/block/whois_online.html
FIND:
REPLACE WITH:
<td class="row1" width="100%"><span class="genmed">{TOTAL_USERS_ONLINE} ({L_ONLINE_EXPLAIN})<br />{RECORD_USERS}<br /><br />{LOGGED_IN_USER_LIST}<br />{ONLINE_BOTLIST}</span><br /><br /></td>
Thanks in advance.
RocknRoll
Re: Separate User and Bots on Index
Post by RocknRoll »
** bump **
WileCoyote
phpBB.de User: WileCoyote
phpBB.com User: WileCoyote
Post by WileCoyote »
Open portal.php
define('IN_PHPBB', true);
define('IN_FORUM_INDEX', true);
Save File
Danach sollte die Anzeige wie gewünscht funktionieren.
lg,
WileCoyote
________________________________________
Get some German MOD Translations at
wu-systems.at - An Austrian phpBB Community
RocknRoll
Post by RocknRoll »
Thank you, WileCoyote.
