block categories
matius
block categories
Post by matius »
Your Portal Version: 1.0.6
Boardlink: http://centrumrc.pl
PHP Version: 3.0.9
MySQL Version: 5.1.58
I tried to solve the problem but without success. Everything that I managed to do is this, but does not work :/
hi,
I want to create a block on the right side, which will show the topic and then the amount of topics. Everything that I managed to do is this, but does not work.
index.php
$forum_id = 4;
    $sql = 'SELECT COUNT(topic_id) AS topic_count
        FROM ' . TOPICS_TABLE . '
        WHERE forum_id = 4';
$topic_count= (int) $db->sql_fetchfield('topic_count');
$db->sql_freeresult($result);
$template->assign_vars(array(
    'TOPIC_COUNT'    => $topic_count,
{TOPIC_COUNT}
Can somebody help me?[/i]
matius
Re: block categories
Post by matius »
Somebody help me?
Where did you add the code you posted?
matius
Post by matius »
what do you mean?
first two in index.php
and last, in block. As I said i'm not very good in programing so I could make a mistake.
matius
Post by matius »
Is it good or not?
