Problem with moving portal.php in other directory
Horeus
Post by Horeus »
Your Portal Version: 1.0.6
Boardlink: http://allgamers.fr
Not write DirectoryIndex portal.php index.php index.html index.htm in /.htaccess
Deactivate Ultimate SEO URL and Zéro duplicate phpBB SEO
Good Morning everybody
In advance, sorry for my english :mrgreen:
I wanted to use the trick in this adress : knowledge/kb_show.php?id=2
for moving /forum/portal.php to /portal.php but it does not work.
I think the problem come to Ultimate SEO URL because it's this is indicated
Create or edit /.htaccess and add:
[code]DirectoryIndex portal.php index.php index.html index.htm
[/code]
Do you have a solution ?
Thanks[/i]
Edit :
Problem solved
In phpbb_seo/cache/.htaccess, must be added :
Horeus
Re: Problem with moving portal.php in other directory
Post by Horeus »
In fact, the problem was not solved ... or almost
If you have Seo Url, do not do the first 2 steps:
Edit /forums/.htaccess
REMOVE
but when connecting, sometimes we fall on page 404. To return to normal, we must go back and refresh. Ditto for the disconnection.
So, I removed it and abandoned.
