Artodia_Helion
- phpBB.com User: ZatchBell68
Artodia_Helion
Your Portal Version: 2.0.0b1
Boardlink: http://www.team-tab.powa.fr
It is for the installation of the portal
Edit html
I just installed your portal and I have a little problem esthetic. Look at the screenshot you will understand better.
If you can help me thank you and good day
Edit html
Re: Artodia_Helion
Search in news_compact_center.html:ZatchBell68 wrote:Your Portal Version: 2.0.0b1
In line 5 of the Code missing.
<span class="portal-corners-top-inner"></span>
Re: Artodia_Helion
The div does not miss the line is as given previously
Re: Artodia_Helion
Refresh your Styles:
Re: Artodia_Helion
I have already done this changes nothing.
Re: Artodia_Helion
Try it in the ACP in the block the Latest news extra column for Post-count and for show number to de-activate.
And try this:
And try this:
open: root/styles/art_helion/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L} <dt <!-- IF S_DISPLAY_NEWS_RVS -->style="width: 44%"<!-- ELSE -->style="width: 60%"<!-- ENDIF -->>{$TITLE}</dt> <!-- IF S_DISPLAY_NEWS_RVS --> <dd class="posts" style="width: 11%">{L_REPLIES}</dd> <dd class="views" style="width: 11%">{L_VIEWS}</dd> <!-- ENDIF --> <dd class="lastpost" style="width: 25%"><span>{L_LAST_POST}</span></dd> {$CC_BLOCK_H_R}
Tip: Replace the preceding line(s) to find with the following lines.Code: Select all
{$CC_BLOCK_H_L} {$TITLE} {$CC_BLOCK_H_R}
Re: Artodia_Helion
And try this:
{$CC_BLOCK_H_L} <dt <!-- IF S_DISPLAY_NEWS_RVS -->style="width: 100%"<!-- ELSE -->style="width: 100%"<!-- ENDIF -->>{$TITLE}</dt> {$CC_BLOCK_H_R}
Re: Artodia_Helion
Last try:
{$CC_BLOCK_H_L}
<dt>{$TITLE}</dt>
{$CC_BLOCK_H_R}
Re: Artodia_Helion
Finally it works great
Thank you very much for your help.
Re: Artodia_Helion
open: root/styles/art_helion/template/overall_header.html
<!-- INCLUDE _sidebar_left.html -->
