Slide Show Block
novanilla
Slide Show Block
I would like to implement an image slide show block for the center of the portal. This is usually a fairly simple script in html, but I don't know how to make something like this work in a portal block. I would prefer it to be integrated with NV's gallery. Any help or good ideas would be appreciated. Thank you!
Re: Slide Show Block
Try it with BBCode in your custom-block.novanilla wrote:I would like to implement an image slide show block for the center of the portal. This is usually a fairly simple script in html, but I don't know how to make something like this work in a portal block. I would prefer it to be integrated with NV's gallery. Any help or good ideas would be appreciated. Thank you!
Nivo Slider BBCode
Nivo Slider BBCode-Demo
Mess
- phpBB.com User: Mess
Looks like something I could use.
Know why they write [DON'T INSTALL] in the title?
Edit:
Arh nm, there is a new one a bit further up.:
http://www.4seven.de/forum/6test/viewto ... ?f=7&t=113
Edit:
