Style Version: 1.0.6
Style Download: http://www.phpbb.com/customise/db/style/lucid_lime/
to: root/styles/lucid_lime/template/portal/*.*
to: root/styles/lucid_lime/theme/portal.css
to: root/styles/lucid_lime/theme/images/portal/*.*
open: root/styles/lucid_lime/template/portal/_block_config.html
<!-- Config for the left and right blocks //--> <!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="width: auto;">' --> <!-- DEFINE $LR_BLOCK_H_R = '</dt></dl></li></ul><ul class="topiclist forums"><li><dl><dd style="border-left: 0px; width: 100%;"><div style="text-align: left; margin: 5px 5px 5px 5px">' --> <!-- DEFINE $LR_BLOCK_F_L = '</div></dd></dl></li></ul>' --> <!-- DEFINE $LR_BLOCK_F_R = '<span class="corners-bottom"><span></span></span></div></div><br style="clear:both" />' --> <!-- Config for the center blocks //--> <!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dt>' --> <!-- DEFINE $C_BLOCK_H_R = '</dt></dl></li></ul>' --> <!-- DEFINE $C_BLOCK_F_L = '' --> <!-- DEFINE $C_BLOCK_F_R = '<span class="corners-bottom"><span></span></span></div></div><br style="clear:both" />' --> <!-- Config for compact blocks //--> <!-- DEFINE $CC_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' --> <!-- DEFINE $CC_BLOCK_H_R = '</dl></li></ul>' --> <!-- Images-URL //--> <!-- DEFINE $NO_AVATAR_IMG = '/images/no_avatar.gif' --> <!-- Vertical distance between left/right and center Blocks --> <!-- DEFINE $BLOCK_DISTANCE = '10px' --> <!-- show Icons in left/right Blocks? 0=no 1=yes --> <!-- DEFINE $S_BLOCK_ICON = 0 --> <!-- postbody top (default 1 by prosilver) 0=no 1=yes --> <!-- DEFINE $S_POSTBODY_TOP = 1 --> <!-- override the column width settings of the ACP for this style? 0=no 1=yes --> <!-- DEFINE $S_COLUMNS_WIDTH_OVERRIDE = 0 --> <!-- override the column width settings of the ACP - set the width if enabled --> <!-- DEFINE $PORTAL_LEFT_COLUMN_OVERRIDE = '200' --> <!-- DEFINE $PORTAL_RIGHT_COLUMN_OVERRIDE = '200' -->
nach: root/styles/lucid_lime/template/portal/*.*
nach: root/styles/lucid_lime/theme/portal.css
nach: root/styles/lucid_lime/theme/images/portal/*.*
Öffne: root/styles/lucid_lime/template/portal/_block_config.html
