Titan (Base: prosilver)
Style: Titan
Style Version: 1.0.4
Style Download: http://www.phpbb.com/customise/db/style/titan/
to: root/styles/titan/template/portal/*.*
to: root/styles/titan/theme/portal.css
to: root/styles/titan/theme/images/portal/*.*
open: root/styles/titan/template/overall_footer.html
open: root/styles/titan/template/overall_header.html
</form>
open: root/styles/titan/template/portal/modules/announcements_center.html
Find and Delete
Tip: Find and delete this code.
<h4 class="first">
Find and Delete
</h4>
open: root/styles/titan/template/portal/modules/news_center.html
Find and Delete
<h4 class="first">
Find and Delete
</h4>
open: root/styles/titan/theme/stylesheet.css
open: root/styles/titan/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div style="padding:0 10px;"><div class="forum-left"><div class="forum-right"><div class="forum-center">&nbsp;</div></div></div></div><div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 0px 0px 2px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</dt></dl></li></ul><ul class="topiclist forums"><li class="row"><dl><dd style="border-left: 0px; width: 100%;"><div style="text-align: left; margin: 5px 5px 5px 5px">' -->
<!-- DEFINE $LR_BLOCK_F_R = '<span class="corners-bottom"><span></span></span></div></div><div style="padding:0 10px;"><div class="footer-left"><div class="footer-right"><div class="footer-center">&nbsp;</div></div></div></div><br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div style="padding:0 10px;"><div class="forum-left"><div class="forum-right"><div class="forum-center">&nbsp;</div></div></div></div><div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dt>' -->
<!-- DEFINE $C_BLOCK_F_R = '<span class="corners-bottom"><span></span></span></div></div><div style="padding:0 10px;"><div class="footer-left"><div class="footer-right"><div class="footer-center">&nbsp;</div></div></div></div><br style="clear:both" />' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div style="padding:0 10px;"><div class="forum-left"><div class="forum-right"><div class="forum-center">&nbsp;</div></div></div></div><div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
nach: root/styles/titan/template/portal/*.*
nach: root/styles/titan/theme/portal.css
nach: root/styles/titan/theme/images/portal/*.*
Öffne: root/styles/titan/template/overall_footer.html
Öffne: root/styles/titan/template/overall_header.html
</form>
Öffne: root/styles/titan/template/portal/modules/announcements_center.html
Finde und entferne
Tip: Finde und entferne diesen Code.
<h4 class="first">
Finde und entferne
</h4>
Öffne: root/styles/titan/template/portal/modules/news_center.html
Finde und entferne
<h4 class="first">
Finde und entferne
</h4>
Öffne: root/styles/titan/theme/stylesheet.css
Öffne: root/styles/titan/template/portal/_block_config.html
