Style Version: 2.0.7
Style Download: http://www.stsoftware.biz/phpbb30_style.acidtech.html
Style Download: http://www.stsoftware.biz/phpbb30_style ... tiger.html
- This Guide is written for AcidTech, but it works for AcidTech Blood / AcidTech Green / AcidTech Purple / AcidTech Lime / AcidTech Yellow / AcidTech Tiger also. If you want to use this Guide for ..Blood ..Green..Purple ..Lime or Yellow you just have to replace "AcidTech" with the Name of your Style in this Guide.
to: root/styles/AcidTech/template/portal/*.*
to: root/styles/AcidTech/theme/images/portal/*.*
open: root/styles/AcidTech/template/breadcrumbs.html
<a href="{U_INDEX}">{L_INDEX}</a>open: root/styles/AcidTech/template/overall_header.htmlCode: Select all
<tr> <td class="navrow">
<tr> <td id="contentrow">
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN and (U_MCP or U_ACP) --> <div class="pm-notify-new"><div class="pm-notify-header">{L_INFORMATION}</div>{L_BOARD_DISABLED}</div> <!-- ENDIF -->
<!-- INCLUDE breadcrumbs.html --> <br />
Tip: Add these lines on a new blank line after the preceding line(s) to find.open: root/styles/AcidTech/template/portal/_block_config.htmlCode: Select all
<!-- Config for the left and right blocks //--> <!-- DEFINE $LR_BLOCK_H_L = '<div class="cap-div"><div class="cap-left"><div class="cap-right"><span style="margin-left: 25px; float: left;">' --> <!-- DEFINE $LR_BLOCK_H_R = '</span></div></div></div>' --> <!-- DEFINE $LR_BLOCK_F_L = '' --> <!-- DEFINE $LR_BLOCK_F_R = '<br clear="all"/>' --> <!-- Config for the center blocks //--> <!-- DEFINE $C_BLOCK_H_L = '<div class="cap-div"><div class="cap-left"><div class="cap-right">' --> <!-- DEFINE $C_BLOCK_H_R = '</div></div></div>' --> <!-- DEFINE $C_BLOCK_F_L = '' --> <!-- DEFINE $C_BLOCK_F_R = '<br clear="all"/>' --> <!-- Images-URL //--> <!-- DEFINE $WHOS_IMAGES = '/images/whosonline.gif' --> <!-- DEFINE $NO_AVATAR_IMG = '/images/no_avatar.gif' --> <!-- Vertical distance between left/right and center Blocks --> <!-- DEFINE $BLOCK_DISTANCE = '10px' --> <!-- show Icons in left/right Blocks? 0=no 1=yes --> <!-- DEFINE $S_BLOCK_ICON = 1 --> <!-- override the column width settings of the ACP for this style? 0=no 1=yes --> <!-- DEFINE $S_COLUMNS_WIDTH_OVERRIDE = 0 --> <!-- override the column width settings of the ACP - set the width if enabled --> <!-- DEFINE $PORTAL_LEFT_COLUMN_OVERRIDE = '200' --> <!-- DEFINE $PORTAL_RIGHT_COLUMN_OVERRIDE = '200' --> <!-- override for rtl styles ... only needed if you have an RTL language --> <!-- IF S_CONTENT_DIRECTION eq 'rtl' --> <!-- DEFINE $LR_BLOCK_H_L = '<table class="tablebg" cellspacing="1" width="100%"><tr><th><span style="float: right">' --> <!-- ENDIF -->
- Diese Anleitung wurde für AcidTech geschrieben, funktioniert aber auch für AcidTech Blood / AcidTech Green / AcidTech Purple / AcidTech Lime / AcidTech Yellow / AcidTech Tiger.
Wenn ihr diese Anleitung für Blood ..Green..Purple ..Lime oder Yellow nutzen wollt, müsst ihr einfach "AcidTech" in diese Anleitung mit dem Namen eures Styles ersetzen.
nach: root/styles/AcidTech/template/portal/*.*
nach: root/styles/AcidTech/theme/images/portal/*.*
Öffne: root/styles/AcidTech/template/breadcrumbs.html
<a href="{U_INDEX}">{L_INDEX}</a>Öffne: root/styles/AcidTech/template/overall_header.htmlCode: Select all
Hinweis: Diese Zeile(n) werden in einer neuen Zeile nach den/der gerade gesuchten eingefügt.Öffne: root/styles/AcidTech/template/portal/_block_config.htmlCode: Select all
