portal_announcements_center
redbull360
phpBB.de User: redbull
phpBB.com User: redbull
Post by redbull360 »
i have been looking into adding the announcement into portal
and this works
but i didn't do this return 'announcements_center.html';
as 2 announcements come up..
please could you look at the code and see if ok to use, its working
    * @package Board3 Portal v2 - announcements Center
    * @ignore
    if (!defined('IN_PHPBB'))
       exit;
    * @package Portal Calendar Alightner Center
    class portal_announcements_center_module
       * top      1
       * left      2
       * center   4
       * right      8
       * bottom   16
       public $columns = 21;
       * Default modulename
       public $name = 'PORTAL_announcements';
       * Default module-image:
       public $image_src = '';
       * module-language file
       public $language = 'portal_announcements_center_module';
       * custom acp template
       public $custom_acp_tpl = '';
       global $config, $template, $phpbb_root_path, $phpEx;
       include($phpbb_root_path . 'includes/functions_announcements.' . $phpEx);
       // Generate calendar week view or next events if required ...
get_announcement_data();
       return '';
          return array(
             'title'   => 'PORTAL_announcements',
             'vars'   => array(),
        * API functions
                return true;
                return true;
