Serenity (Base: subsilver2)
Style: Serenity / serenity_darkblue / serenity_green / serenity_cyan / serenity_purple
Style Version: 2.0.7
Style Download: http://www.stsoftware.biz/phpbb30_style.serenity.html
This Guide is written for Serenity, but it works for serenity_darkblue / serenity_green / serenity_cyan / serenity_purple also.
If you want to use this Guide for ..darkblue ..green ..cyan or purple you just have to replace "serenity" with the Name of your Style in this Guide.
to: root/styles/serenity/template/portal/*.*
to: root/styles/serenity/theme/images/portal/*.*
open: root/styles/serenity/template/breadcrumbs.html
open: root/styles/serenity/template/overall_header.html
	<td class="navtd">
	<td id="contentrow">
open: root/styles/serenity/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div class="cap-div"><div class="cap-left"><div class="cap-right">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</div></div></div>' -->
<!-- DEFINE $LR_BLOCK_F_R = '<br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="cap-div"><div class="cap-left"><div class="cap-right">' -->
<!-- DEFINE $C_BLOCK_H_R = '</div></div></div>' -->
<!-- DEFINE $C_BLOCK_F_R = '<br style="clear:both" />' -->
Diese Anleitung wurde für Serenity geschrieben, funktioniert aber auch für serenity_darkblue / serenity_green / serenity_cyan / serenity_purple.
Wenn ihr diese Anleitung für ..darkblue ..green ..cyan oder purple nutzen wollt, müsst ihr einfach "serenity" in diese Anleitung mit dem Namen eures Styles ersetzen.
nach: root/styles/serenity/template/portal/*.*
nach: root/styles/serenity/theme/images/portal/*.*
Öffne: root/styles/serenity/template/breadcrumbs.html
Öffne: root/styles/serenity/template/overall_header.html
	<td class="navtd">
Öffne: root/styles/serenity/template/portal/_block_config.html
