Problem with board module cell spacing
amstel78
Post by amstel78 »
Hello all,
I recently installed Board3 portal v2.0 and am running phpbb 3.0.10.
The portal works fine except the cell spacing on the module boxes is incorrect. It appears shifted up. You can see what I mean when you go to my portal:
http://knights.jamespaulsarte.com
I am not sure where to look to correct the alignment of the boxes. Can someone please tell me what needs to be done?
Thank you.
Re: Problem with board module cell spacing
Please add what browser and what version of that browser you are using. I can't see anything wrong.
amstel78
Post by amstel78 »
Sorry about that; that's because I just fixed it.
I found that I had to edit this line in the _block_config.html file:
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 0px 0px 8px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
Where it says "dt style="padding: 0px 0px 8px;", I changed the last digit from 2 to 8px. It moved the border down.
Now I'm wondering how to remove any gap between the lighter shade inside the module box and the outline of the box itself. Is that possible?
Thread moved to Styles support.
A download link for the style would be helpful. ;)
amstel78
Post by amstel78 »
archivar wrote:Thread moved to Styles support.
Here is a link to the style:
http://www.phpbb.com/community/viewtopic.php?t=2125167
The style is phpBB v. 3.0.8!
Replace the contents of _block_config.html:
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 0px 0px 6px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $LR_BLOCK_F_R = '<span class="corners-bottom" style="margin-bottom: -5px; margin-top: 0px;"><span></span></span></div></div><br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dt>' -->
<!-- DEFINE $C_BLOCK_F_R = '<span class="corners-bottom" style="margin-bottom: -5px; margin-top: 0px;"><span></span></span></div></div><br style="clear:both" />' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
Remove it in portal-style files attachments_center.html, custom_center.html, poll_center.html, welcome_center.html :
panel
amstel78
Post by amstel78 »
Thank you for your help. I will try what you have suggested.
Edit:
Thank you so much for your help. The portal looks so much nicer now that I was able to incorporate the edits you suggested. You may see how it appears at our new domain name:
http://cn-knights.net
I was hoping to ask you a favor. It seems I have a similar problem with the cell spacing in the actual forum itself. I realize now that this style is for 3.0.8. Since you did not create this style, you are not responsible for providing support but it seems you may be the best person to ask. If you are willing to assist, what files in the main template do I need to edit so I can also make the forum blocks look nice and neat like the portal?
Thank you very much! :mrgreen:
amstel78
Post by amstel78 »
Disregard. I fixed it by modifying the theme's common.css file.
Thanks again.
amstel78
Post by amstel78 »
Oops!
After I fixed the forum cell spacing by modifying the common.css file, the portal borders got messed up again. This time, the bottom of the tables are protruding past the cell border.
http://cn-knights.net/portal.php
Sorry, but not sure what variable in _block_config.html has to be edited to compensate. Could you please tell me?
This is what I added to the common.css file:
    .forabg span.corners-bottom, .forumbg span.corners-bottom, .forabg span.corners-bottom span, .forumbg span.corners-bottom span {
           height: 0;
In context:
    span.corners-top, span.corners-bottom, span.corners-top span, span.corners-bottom span {
       font-size: 1px;
       line-height: 1px;
       display: block;
       height: 5px;
       background-repeat: no-repeat;
           height: 0;
    span.corners-top {
       background-image: none;
       background-position: 0 0;
       margin: 0 -5px;
amstel78
Post by amstel78 »
Disregard. I found the right variables to modify in the _block_config.html file.
Return to “Styles Support”
