Hello Board3 Portal staff.
I want to know how I can uninstall it ?
I don't see any uninstall file in the downloaded package , so can you help me to uninstall it ?
Thanks .
How to uninstall Board3 Portal ?
Re: How to uninstall Board3 Portal ?
If you upload the /install/ directory, then got to /install/install.php there is an uninstall option.
May I ask why you are uninstalling Board3, are you not happy with it, and if so, what's wrong? We can't make it better without input from our users.![Lächeln :)](./images/smilies/icon_e_smile.gif)
Reasons why I have uninstalled Board3 Portal :
1) I have a new board , I don't have some much members so i need new members and i think that with the board without the portal i will have more members in the difficult start.
2) I will try a SEO mod , wich is called phpBB-SEO[dot].com , so this mod is not compatible with board3 portal.
In the future if memerbs ask for or want a portal , I wil reinstall Board3 Portal .
I'm very happy with your work so keep it alive
