I need a simple recents topics, that show only the lastest topics, user and date , to put in the side of portal, with up marquee.
Something like the block that a have in the right of my old portal:
http://www.portaldetonando.com.br/forumnovo/portal.php
Simple Recent Topics
Re: Simple Recent Topics
Hey oki,
I was thinking the same thing, and decided to take action myself. With no knowledge of php whatsoever, I set out to do what seemed the impossible. But with a little figuring things out, I modified the latest bots (like anyone is ever going to use that) to display the latest posts. So basically open latest_bots.html in styles/yourstyle/template/portal/block in wordpad or whatever you use and replace everything with this:
When you activate latest bots, it will put this up instead, which shows the latest topics. Of course, I take no credit whatsoever as I simply synthesized the recent topic center block and the latest bots side block.
Also this code:
is for having a little icon beside each of your posts. I thought that it was kind of cluttered looking, so adding a little icon made it MUCH nicer in my opinion. Once again, this was ripped from the latest members. You just need a 15x15 gif file called post.gif in portal/images/post.gif
The code that says:
is obviously the title of the block.
I wish I could add who wrote it and such, but that is beyond my skill. I literally started all this portal stuff yesterday, and have zero experience with php. So if I figure things out, I'll try and update this post and let you know.
MAJOR PROBLEM: The big chunky recent topics must still be in the forum for this to function, I pushed it to the bottom. If anyone knows how to do this without the big one, please post!
<!--version $Id: latest_bots.html 216 2008-04-29 07:23:22Z kevin74 $ //-->
<th>Latest Posts</th>
<tr class="row1">
<td>
<!-- BEGIN latest_topics -->
<img src="portal/images/post.gif" height="15" width="15" alt="" /><a href="{latest_topics.U_VIEW_TOPIC}" title="{latest_topics.FULL_TITLE}">{latest_topics.TITLE}</a><br />
<!-- END latest_topics -->
Also this code:
The code that says:
Just as a hint:PharaohsVizier wrote:So basically open latest_bots.html in styles/yourstyle/template/portal/block in wordpad or whatever
I would strongly recommend not to use wordpad for editing php and template files! That caused a lot trouble in the past.
See: [EN] Editing phpBB (language) files the right way
Second: no need to change the latest bots file - you could work with a copy of it.
To get it on the portal see:
Adding a custom block
Cheers
Thank you for sitting down and working this out, I never thought of that and I like you, don't like the Large "recent block" in the middle of my board. To make your "Latest Post" block work woth out displaying the large one you need to make sure that the "Recent Topic" it is turned on in the ACP under the .MOD tab.
Then go to portal_block.html and remove that will leave the switch that turns on the info from the Recent block, but of course you have removed it from the display by removing the code from portal_block.html.
hope this helps out
<!-- IF S_DISPLAY_RECENT -->
<!-- INCLUDE portal/block/recent.html -->
hope this helps out
Wow, clearly I still have lots to learn.
Thanks so much, working like a charm, not big recent topic block for me.
I did this, and its better. But I want it more like the one they have here: http://www.edgeofnowhere.cc
Thats a portal from 2.0 called Nutport. He doesn't update it anymore. But I love how they have the recent topics set up. Looks more organized, with the last poster's name at the bottom of the topic name. Is there anyway to do something like this with this portal using the online bots thingy. Here's my board:
http://www.diablosden.hugelaser.com
l'ho provato e funziona bene!
Ma c'e il modo di visualizzare,oltre al titolo del post, il nickname dell'autore del topic e la data di invio?
I tried it and it works fine!
But there's a way to view, in addition to the post title, the nickname of the author of the topic and the date of dispatch?
EDIT:
Topic-Bumping is only accepted at least 24 hrs. after posting.
Board3.de - Rules | We ask for your attention
Greetings archivar
EDIT:
Greetings archivar
I would get a block like this
how can I do?
how can I do?
