This is a simple block I put together so I could have a "pic of the moment" thing on my portal. It randomly pulls an image from my Coppermine gallery and displays it in the block.
I came across the Coppermine part of the code on the forum there.
First, make a file called get_photo.php in /root/coppermine (or wherever you gallery is installed.)
// Coppermine Photo Gallery - RSS Feed //
// Copyright (C) Dr. Tarique Sani //
// http://tariquesani.net/ //
// Adapted by djib to display a random photo - http://djib.biz //
// This program is free software; you can redistribute it and/or modify //
// it under the terms of the GNU General Public License as published by //
// the Free Software Foundation; either version 2 of the License, or //
// (at your option) any later version. //
// Just put into the same directory as your coppermine installation //
define('IN_COPPERMINE', true);
define('INDEX_PHP', true);
require('include/init.inc.php');
//How many items you want to show in your get_photo script
if(isset($_GET['nb'])) {
$thumb_per_page=$_GET['nb'];
} else {
$thumb_per_page = 1;
$thumb_count = 1;
$lower_limit = 0;
if(isset($_GET['album'])){
$album = $_GET['album'];
//If it is a numeric album get the name and set variables
if ((is_numeric($album))){
$album_name_keyword = get_album_name($album);
$CURRENT_CAT_NAME = $album_name_keyword['title'];
$ALBUM_SET = "AND aid IN (".(int)$_GET['album'].")".$ALBUM_SET;
//Set the album to last uploaded
$album = 'random';
//If the album is not set set it to lastup - this is the default
if(!isset($album)){
$album = 'random';
//Changes these to point to your site if the following is not giving correct results.
$link_url = $CONFIG['ecards_more_pic_target']."displayimage.php?pos=-";
$image_url = $CONFIG['ecards_more_pic_target']."albums/";
$data = get_pic_data($album, $thumb_count, $album_name, $lower_limit, $thumb_per_page);
foreach($data AS $picture) {
$thumb_url = "$image_url$picture[filepath]$CONFIG[thumb_pfx]$picture[filename]";
$description = '<a href="' . $link_url . $picture['pid'] . '" target="_blank"><img src="' . $thumb_url . '" border="0"/></a>';
echo $description;
?Code: Select all
<div class="forabg2">
<div class="inner">
<ul class="topiclist">
<h3>Screenshot</h3>
<ul class="topiclist forums">
<iframe src="http://www.fliggerty.com/coppermine/get_photo.php" align="center" border="0" width="120" height="120" frameborder="0"></iframe>
<br style="clear:both" />Next, edit portal_body.html and add this where you want the block to show up:
<!-- INCLUDE portal/block/random_shot.html -->I hope someone else can find this to be a useful thing!
--Fligg
