Your Portal Version: 2.0.1
Boardlink: http://mtc-heerhugowaard.nl
I installed the board3 portal.
revert back to backup.. start install again.. and follow each and every step... no joy what so ever.
Hi After trying to install the portal twice now I still cannot get the admin part for the portal modules to show correctly. When I installed it in test it worked fine (older version) however now in a new environment I only get the variable names to show instead of the user friendly names..
they show like:
{ MODULE_NAME }:
{ MODULE_NAME_EXP }{ MODULE_RESET }:
{ MODULE_RESET_EXP }{ MODULE_STATUS }:Ja Nee{ MODULE_PERMISSIONS }:
{ MODULE_PERMISSIONS_EXP }
etc..
Can you help me with this?
Admin Module shows links as {current_version) etc.
mtcheerhugowaard
Re: Admin Module shows links as {current_version) etc.
It lacks the language files.
Controlling again whether you have uploaded everything.
heiner
- Valued Contributor
- phpBB.de User: HirschHeinrich
- phpBB.com User: HirschHeinrich
in supplement to Kirk,
ur board default language is "nl". Board3portal comes with "en".
Therefore were portal languagefiles not found.
You should copy the portal language folder with all files from path "urforum/language/en/mods/portal/*.php" into folder "....../language/nl/mods/....
Userfriendly these files then should be translated (UTF8 without BOM).
Also is recommendable to begin with default style prosilver (not subsilver2).
I hope this was helpful.
Heiner
Searching i found this: viewtopic.php?f=13&t=9402
Heiner
mtcheerhugowaard
For some reason the files where on the server and in the right location. I verified if it was the correct file and content.. it still wouldn't work.
I had both EN and NL language files installed.
I removed the files and reinstalled them.. now it is working..
Thanks for the help.
